This command configures the report mode for a collector.
all | Configures report mode for all report collectors. |
hostname | Configures report mode based on the host name of the collector. |
ip_address | Configures report mode based on the IPv4 address of the collector. |
automatic | Automatically reports switch status to the configured collector (Default). |
manual | Manually reports switch status to the configured collector through the run tech-support report. |
Disabled.
If enabled, the automatic collector is the default report setting.
This command configures the report mode for a collector. When you specify all, it configures report mode for all existing collectors, otherwise it configures report mode for a particular collector specified by the hostname, or IP address. When the report mode is set to automatic, the switch automatically attempts to connect to the cloud-hosted collector, and reports the switch status information based on the frequency and data set setting of the collector. Changing the configuration to manual restricts reporting to user initiated mode using the run tech-support command for that collector. When a collector is added, the report mode is set to automatic by default.
The following command example configures the report mode on all existing collectors:
configure tech-support collector all report
This command was first available in ExtremeXOS 15.4.
